Enables the display of CLI commands and responses during script operation.
During interactive script sessions: CLI scripting output enabled.
During load script command operation: CLI scripting output disabled.
When the CLI scripting output is enabled, all script commands and responses are displayed.
When the load script filename {arg1} {arg2} ... {arg9} command is entered, the software disables CLI scripting output until the script is complete, and then CLI scripting output is enabled. Use the enable cli scripting output and disable cli scripting output commands to control what a script displays when you are troubleshooting.
The following command enables CLI scripting output for the current session or until the disable cli scripting output command is entered:
This command was first available in ExtremeXOS 12.1.2.
